diggum smacks
- Apr 26, 2014
- 7
ok.. i was out fishing one day.. boat ran fine... anchored up... upon moving to a new spot.. boat started this.. backfire type thing... when ever i would rev engine in neutral at the end of the rpm band i would hear a ..." what" style sound... i called a shop.. they said timing.. so i ordered a manual for the motor... in the mean time... since i had 3 carb rebuild kits already and 3 brand new coils.. i went through the motions.. upon finishing i noticed... motor was still givin me what whuut at the end of a rev.. none of these carbs have needle valves or what seems like any adjustements other than float height... i was told i did something wrong... so took the carbs back off.. went over them again.. engine got worse... so went over them one more time.. and again.. no change.. getting a blueish style smoke out the motor.. i dont have timing specs so i cant even put a timing light on it to see if it is indeed out of time or if its just a carb prob... all 3 cylinders have 130 psi so... i have no clue what to do now. ive read other posts and you guys seem to know your stuff... im pleading... help
