Good Afternoon
I have a 1985 Evinrude 60 hp (E60TLCOD) that has woken up from a 10 year hibernation....Rebuilt carbs, switched over to a fuel pump vs. the VRO...The problem I?m having is it has a rough idle when the fast idle lever is down on the remote control?It idles fine with it half way up.....I have the idle adjustment screw at the motor set to its full throw and need a 1/4 inch more....Should I just put a longer screw in or should I be looking else where..
