Been pouring through information here looking for similar problems and fixes. Some seem close to what I'm experiencing so I think I have some places to start, but wanted to run my situation by you guys just in case something else could be the problem with my evinrude.
I transplanted this motor to the back of a project pontoon (done by a mechanic). Put it on muffs and had to run some starting fluid to get it going in the driveway (fresh fuel, marine grade oil 50:1). Seemed to run well, so I took it to the lake for a test spin. The motor seemed to start easier in the water which was promising. I had to make some adjustments to the shift cable, as it was not properly connected in the throttle control box at the helm, but after it seemed to shift in F-N-R just fine.
Gave it some gas and got up on plane. It ran great for about 3 minutes and I got it close to WOT, but then lost power down to about idle. I didn't let off the gas, and after a minute or so it took off again. Less than a minute later it lossed power again down to about idle so I put it in neutral. At that point, it idled really high and kind of rough. Almost sounds like a back fire. I adjusted the throttle down at idle, and the next time it "back fired" it killed the engine at the lower idle RPM's. Restarted it with no problem though, but the problem continued.
Brought it home and added a "pee hole" just to make sure water is running through the water jacket properly. Ran sea foam through the carbs to clean out junk and replaced all spark plugs. I moved over the automatic choke heat sensor wire to primary to bypass a possibly faulty sensor. Ran pretty well in the drive way, but I can still hear a miss or back fire even after new plugs, and it would occasionally die if the "misfire" was a bad one...for lack of better terms.
I'm guessing my next move is to replace the power pack, but I really don't know how to verify that. Or the rectifiers?? Or is this possibly a bigger problem than that? Any help is greatly appreciated!! Please forgive my lack of mechanical vocabulary...you guys must have the patience of Job!
Thanks in advance!
Thanks in advance!
