danthemanx07
- Apr 25, 2014
- 6
I have a 1991 140hp Johnson. It runs great at idle, starts easily, and otherwise is a great running motor.
Its problem is that it won't make more than 4100rpms. Here is what I have checked so far:
1. Even compression, 120-125 across all 4 cylinders.
2. Carbs were rebuilt last season when the problem developed. The jets are clean and clear. Low jet= 37, Med = 54 and high = 63D.
3. I had a new control box and cables installed last year. Throttle cables were adjusted by a qualified mechanic at that time.
4. All coils and spark plug wires were replaced last season.
5. I have been trouble shooting with both a 6 gallon portable tank and the main tank to isolate any fuel supply issues. No change between the two.
My course of action for further investigation is:
1. Picked up a spark tester last night. Will be checking on that asap.
2. Will be picking up new spark plugs tonight. The ones I pulled looked a little dirty. I will get a picture up.
My question is where to go from there? What should I look at next? All of the threads I have read seem to go dead shortly after the OP tests spark. Maybe they get it fixed and just don't report back? Not sure, but either way, I havent been able to find much beyond that.
Thanks for help.
Daniel
Thanks for help.
Daniel
