Re: 1982 Evinrude 90hp Idle
Perhaps there is an issue with the engine.------No amount of adjusting will correct for a motor that is in poor condition,--------First do a compression test.-----Then check to make sure you have spark that jumps a 3/8" gap on all leads.------If those are good THEN look into adjustments.
