johnlazelle
- Apr 20, 2014
- 30
Hi all,
I have been working on this motor that has not been run in almost 15 years. I spent the winter cleaning it up and tuning it. I replaced the fuel pump, fuel lines, new spark plugs, cleaned up the points, new water pump, changed the oil in the lower unit, rebuilt the carb, repaired spark plugs wires.
Finally got to the point to run it and it starts, but runs rather rough and there is gas dripping out of the carb. The engine does some "popping" and sometimes stalls.
I guessing i need to make some adjustments and am looking for some advice.
Thanks,
John
Thanks,
John
