Thing is the ignition switch is gone,only the wiring conections behind it is left,all wires are still conected to this back-ring i call it. when i connect cable pluss and minus on batteri,the starter cranks right away,have to remove minus cable and then it ofcourse stops.
pic is random google.
colors is: two black,one red,one purple with white stripe,one black with yellow stripe and one white.
im asking, if i remove all wires from this ring,wich one should touch eachother so i can start it "normally" with cables constant connected to battery?
