Re: 1977 140hp Johnson bubble back
The original factory power packs for this engine were unlimited. Those have been discontinued years ago. Unlikely you still have two original factory packs. If you purchase a replacement from Bombardier today, it will have a 5800 rev limit. Just one new pack at 5800 will limit the engine to that rpms. That engine could still make strong hp over 5800. The 5800 is not a bad rpm for that engine, it makes strong torque at that point and should perform well for you throughout your ownership, if propped to run WOT at 5800. Anything less than that, (like 5200 or 5300) and you will give up hp/performance. So prop it to turn 5800 with yourself in the boat and a light load of fuel, at full trim (out.)
