I bought an older boat last year, the motor is a 1983 v-4 140 johnson outboard. Had it in the water and it ran good for a short while. then it seemed like it just bogged down. Or powered down I guess you could say. As you can tell I know nothing about this. Way out of my league, So I figured I would ask here and see if I might find out what it could be before I took it too yet another mechanic. The last one checked everything and said the only thing he could fine was a thermosat issue.. which he replaced, that cost me 300.00. We put it in the water and just like before. Its starts ok and runs ok. Powers up well. Then all of a sudden while crusing along it just seemed power down and even with the throttle wide open it would go no faster. I took it back to the same guy another 200.00 for some repairs. Tried it again and still the same thing, he then said it would be best to take it to someone else. I thought to myself. You are right. Duh. LOL And this is how he makes a living. So yes I am a bit reluctant to deal with theses guys. I parked it. Now So yea I wanted some type of idea as to what the problem might be before hand.. Below is what I was told had been done by the mechanic. replaced right head gasket and thermostats, left and right power packs checked and cleaned grounds on coils and power packs..any ideas??? someone said maybe the wiring shorting out? IDK
