I have 1977 Evinrude (85799S) that I am trying to time.
My biggest problem is that the book I have covers many models for a decent range of years, and evn when I read the part that seems to be for my year/motor, it describes adjustments that my motor doesn't seem to have.
Here is what I have so far. To get the pick up timing right, the book made it seem like there was a screw that would rotate the cam that interacts with the carb throttle lever to where I want it to be. The only way I see on my motor to do this was a plastic piece threaded onto the control arm that could only be adjusted by removing 2 cotter pins, and unhooking the cam to free it. A combination of messing with that and adjusting the contact on the carb achieved lining up the mark correctly. I think I did this right, but it was no where near what the book described, and thus my discomfort.
The other and more difficult issue is the actual timing and idle. Here is where I am greatly confused.
My understanding is that at idle, and for the initial range of acceleration the throttle plates remain closed and the engine is accelerated solely by timing advance, until a certain point after which the throttle plates open in concert with the timing continuing to advance.
The book says I am looking for 4-5 degrees BTDC at an idle RPM of 6-700. My confusion is this. The motor "sounds" decent at around 8-900 rpm. At that rpm, the timing is almost at TDC, assuming the pointer is correct. I can advance the timing, but obviously the rpm will go up.
The book implies that I should be able to adjust timing and idle separately, but I see no way to do this. I don't see how I can advance the timing while maintaining the idle rpm I should have. My understanding is that the carb has fixed orifices, so what else is there? Once the throttle plates are closed, what other way besides retarding timing is there to slow the idle?
I just rebuilt the carbs if it matters. I leveled the floats, if that makes a difference. The engine runs the same as it did pre-carb rebuilds.
