I have replaced the plugs and wires. Cleaned and went through each carb. Replaced the reg. rect.
Its a random act only at idle once in gear its fine runs great all day long. If I pump the primer ball this some times seems to get better the fuel pump was changed also no difference from the old to the new fuel pump. here is a video of another boat I found on you tube that mimics what mine is doing
Motor Sputter - YouTube
