I have a 1990 Evinrude 3hp that's been sitting for about 5 years, its got strong compression and maybe 10 hours of use on it since new.
It was winterized and stored indoors with a dry fuel tank and fuel system.
I got it out the other day, put some gas in it and ran it in a trash can full of water. It fired up on the second pull, ran for about a minute then shut off, it will restart only with full choke and it repeats the start/run/stall over and over again. A couple of times it ran long enough to shut off the choke but it stalled again. It never loses spark, its running out of gas. This motor has an on motor fuel tank.
I pulled the carb bowl, all looks super clean inside but I didn't go any further. Any ideas where to look?
