Hello again,
As I was bottoning my engine up after gearbox re-seal, I noticed a distinct difference on the Sierra powerhead to exhaust tube gasket then what shows in the Johnson parts catalog.
The Johnson original p/n is 304314, Sierra's 18-2894.
Other than some minor slot differences (no concern) the major question is regarding the gasket over the water tube opening. On the Sierra, it is closed over. On the Johnson part detail, it has an opening as one would expect.
Is this right? I wouldn't think so. See diagram attached.
Surely you experienced hands have noticed. Should I just cut in the hole with a razor knife?
Regards,
JimVmd
Regards,
JimVmd
