outboards115
- Apr 19, 2012
- 166
Hi,
I have a 60 hp Johnson, not the 3 cylinder ones, its an old V4, I cant to get it running right, when I first got it the carby was blocked and I cleaned it out along with the fuel pump/filter and it ran all good then it started running on 3 cylinders but had spark on four do I cleaned the points and that solved that problem but started not running right again so I re- adjusted the throttle synch with the distributor, there was a youtube video that showed me how to do that (which was on a 75 hp Johnson but threr was all the same adjustments on mine), I can post it and see what you think but it made sense to me, so I did all that and its now running on one cylinder so now I'm stuck on what to do. if anyone could help me that would be great!
https://www.youtube.com/watch?v=wUX4rdDIQvM
Model: VXL12R
Serial: SA28159
Model: VXL12R
Serial: SA28159
