sailnaked6842
- Apr 7, 2014
- 4
Hey guys, been reading your threads a lot and they've been a wealth of information for helping me take apart my motor. But currently the motor is almost all the way apart, ready to take to a machine shop to remove some stuck bolts and hone/bore the cylinders...except the powerhead is stuck. Really stuck. My father and I attempted to remove the powerhead this morning and removed (or at least broke the heads off) the bolts holding it on. I believe there were 3 on both sides, 2 studs with nuts in the front, 2 bolts in the front, and 2 studs with nuts in the rear. After removing all the bolts, we positioned the engine under a lift and no matter how hard we tried could not get the motor off the base. Definitely in the realm of ~5-600 lb-force, but it wouldn't break free. Is there anything I'm missing? Heard a little about a shift linkage but my Seloc manual says nothing about needing to remove that. Is it possible the drive shaft froze to the crank? I can post pictures too if that will help.
