Re: lower engine cover hole? 88' 20,25,30,35 johnson/evinrude
Depending on the year, the air intake may be in the rear of the top cowling, behind the plastic horsepower/logo bit below the grab handle. Later cowlings had the air there, earlier ones had it in the belly pan under the carb. The outline for the belly pan hole is still there as they didn't change the casting any more than they had to to change the location. I learned this the hard way when I tried to put an early cowling onto a later motor and inadvertently close off all air intakes! Drove me nuts till I figured that one out... Not certain, but I suspect they did it to move the noise source to the back of the motor to make it a bit quieter.
