Re: 1978 Evinrude 140 tach hookup
What color is that wire?
Does that wire lead to the internal portion of the tachometer? If not, what is the terminal marked on the tachometer that the wire is attached to?
Normally the wire is purple in color and is attached to the "A" terminal of the igniiton switch. This allows 12v to be applied when the key is in the ON or START position to the tachometer voltage supply section and the light bulb if so equipped... BUT... it is best to be sure about where that wire is leading to on the tachometer and its coloring.
