Could you post a model number?
It sounds like the interlock, but the model number will have the information needed to look it up.
Look it up on -----shop.evinrude.com-----Order from your local dealer if you feel you need this safety item.----Perhaps it was removed because of motor issues ?
Go to shop.evinrude.com and look up your motor. Good parts diagrams.
Outboards are " quite special "--------Lots of folks have ideas about them.----Then they ask questions and won't believe answers from folks with 40 + years of know how.
Statement ---" I checked the mixture "---means nothing in itself.---How did you check the mixture ????---What did you do ????
The suggested ratio of gas to 2 cycle engine oil is supposed to be 50 to 1. I measured it at 50 to 1.
