RyanInFlorida
- Jul 20, 2008
- 23
I have a 1993 Evinrude 140HP- TLETF that is not currently charging and the tach is not working. The rectifier shows the following model #584205. It has a red wire, purple wire, grey wire, yellow wire and yellow wire with grey stripe.
This is the testing procedures I'm using below not sure if this is a bad rectifier? I don't want to be one of those people that just keeps throwing parts only to find out I have the same problem. :mad-new:
I have a multi-meter set on the diode option that looks like this ->|-
Here are my results below:
With the black on ground screw and red touching the following leads
Red- 1
Purple - 1900 for a about a second and then back to 1. Not sure if it should stay constant?
Grey - 1
Yellow -1
Yellow/grey stripe- 1
switched the leads from red on the ground screw and black touching the following leads
Red- 1
Purple - 1
Grey - 1
Yellow -1
red on the red wire and black touching the following leads
Purple - 1
Grey - 1
Yellow -1
black on the red wire and red touching the following leads
Purple - 1
Grey - 1
Yellow -1
Yellow/grey stripe- 512
Would this tell me it is bad? Or am I still missing something or am I testing the rectifier the wrong way? Any thoughts would be appreciated.
Thanks ahead of time.
Red- 1
Grey - 1
Yellow -1
Red- 1
Purple - 1
Grey - 1
Yellow -1
Purple - 1
Grey - 1
Yellow -1
Purple - 1
Grey - 1
Yellow -1
