How do you clean inside your lower units when water and oil is "mixed" together? i have now drained it as much as i can the normal way. first ting that hit me is to set air pressure on top hole, and let it blow out bottom oil-hole? diesel may work well to kind of flush inside lower unit as the sludge was nasty? k
