Here's the rundown... after first trip out this summer I decided to dump some money in this ole boat and try to fix it. I ordered service manual, got all gauges back working, rewired all the switches to working order, replaced the stator, glued a couple magnets back under flywheel, replaced regulator/rectifier, 2 new power packs, all 6 ignition coils new, 2 new thermostats, new plugs and wires, rebuilt fuel pump (fuel side only, oil is plugged and I premix), doel fin, new fuel lines and primer bulb, new inline filter/water separator, linc n sync, timing set to 24* (Joe Reeves method so its really at 28*). I took it out today and I must say it ran A LOT better... BUT.. still a few things:
1: Idling only abut 500 rpms, would like to know how to get that closer to 7-800 rpms.
2: Up to 4000 rpms this thing runs excellent, after 400 rpms it starts surging. Loses 1000-1200 rpms, then it picks it back, loses it, then picks it back up all without me touching the throttle. Pumping primer bulb and choking doesn't affect it, still does the same thing. What could this be?
3: At WOT I'm runnin about 55-57 mph, BUT Im only at 4500 rpms. This was my first trip with a working tach.
4: I noticed after runnin up the lake and stopping to fish, I leave n oil trail for about 5 minutes?
PS: The prop is 14 1/2 by 24 3 blade stainless. Its not horrible... but its not great either. The blades have ate their fair share of rocks. None are bent but the edges of them are beat up pretty bad. What would be a good size to go with? Could the prop possibly be causing this situation?
Thanks in advance!
Thanks in advance!
