eloham1979
- Mar 20, 2014
- 20
Okay I will start from the beginning I have a 14 foot boat a friend lent me an my son for the summer he said the 18 hp Evinrude had not been run for a few years but he had bought a carb kit an said that should get it going I cleaned the carb in berry man an then in my ultra sonic cleaner an then installed all new kit I had to clean the points up an I noticed the upper seal leaking there was a lot of oil in an around the points so I removed the stater plate cleaned everything well an replaced the plug wires an points an condenser an put coils on it so ignition system is now all new I got it fired up it smoked like a pig for about an hr an then cleared up an ran good I thought I was about ready for a water test the next day I cranked it again just to see how close I had the carb adjusted it started on about the 4th pull but was backfiring but only on low end throttle smooths out good on upper end I noticed fuel in the pan under engine an checked the hoses this fuel is literally leaking out of the intake manifold I was told it was the reeds causing this so I bought 2 new reeds an neww gaskets an put them in an just to rull out the carb I turned it upside down an put my little mighty vac to it an pulled 15 inches of vacum an let it sit it held it just fine an I left it almost a hr an it did drop to 14 but considering I just had a hose stuck on it I figured that's not bad I also did the same to the fuel pump on the block I pulled a vacum on it the diephrams are fine an I checked it at the block it's good I put it all back together an it cranks right up but after about 10 minutes it goes to leaking fuel out the intake an out the exhaust I did a compression check an have 110 pounds on upper an lower cylinders it has great fire white an blue very strong you can here it crack when you spin it not sure what else to check I also checked the key way an have put a new one in any help would be great
