eloham1979
- Mar 20, 2014
- 20
Hi I have a 1972 Evinrude 18 horse on a 14 ft a friend left me to use for the summer he said it sat for a few years I checked fire it had weak fire on one so I replaced the old wires and the points and both coils eventually I did not use new coils but got the same result I cleaned the carb it has a brand new kit an I have got it to run it smoked like a pig for a while an cleared up an ran well the next day it would not start it backfired at me I pulled the plugs an they where soaked an had lost fire I then put this set of coils in used an same result it runs an runs rough at low rpm put smooths right out under throttle but it was starting to backfire an sheared the keyway so I replaced it got it to run again an I noticed there is a vacuum line under the carb that goes to the upper cylinder an I noticed it has gas in it it seems to be a one way valve in the intake not sure the valve seems to be working not sure why it keeps flooding it has raw fuel in intake manifold an I went back in an tweaked the float at this point I don't really want to bend it to much more as I felt like the amount I tried was a lot it runs great under a load as well just low an an all parts in carb are new except float an it is good the carb is spotless any clue's
