Re: Changing Power Pack 85 Johnson GT 150
My 86 factory manual should shows the standard wire routing for the three orange power pack wires on each head: orange wire with blue tracer goes to the top plug coil, the solid orange wire goes to the middle plug coil, the orange wire with the green tracer goes to the bottom plug coil. If you get them on the wrong coil, you will wind up with a violent backfire as the engine tries to run. You can see this wiring diagram on this website-check out the first thread at the top of the first Johnson/Evinrude forum page, called the "top secret" files. It has a 1985 color diagram that will confirm your wire routings.
