FishinDave
- Jun 12, 2012
- 46
1985 Johnson model J10RC0M. I Changed the carb on this motor with a 15hp. I research and it seems that the carb is the only thing that I need to change on this motor so i did. The boat ran great with me in it. Then me and a buddy went fishing and the thing would not get up on plane. It felt like it was doing 5 miles an hour with us in it and with just me in it, it felt like it was doing 25mph. I messed with the transom swivel bracket pin and adjusted the motor and set it at different positions in the water and still slow slow slow. I let my buddy out at the ramp and did a test run again and she flew. First question is how can i have this much difference with another person in the boat? Next question is does a dolphin fin really help get a 15hp on plane? 3rd question is what pitch/length prop should i use on this motor with my 14ft tracker jon with front and back decks. My buddy has the same setup as me but he has a 9.25x8 prop and mine is a 9.5x10. His boat pops right out of the water but he also has a true 15hp. Last question = Is the carb the only thing that needs to be change on this motor. Everything I found says yes and it goes faster than the 9.9hp did with just me in it. I am almost positive that the tuned exhaust started being used in 1981. I am going to drop the lower tomorrow and make sure that it has the tuned exhaust tomorrow. Thanks for any help in advance.
