Re: Johnson 150hp Outboard compression
Compression will vary with the cranking speed. The cranking rpm should be close to 300 rpm. Normally the compression on the starboard bank would be in the 100 psi range with the port bank being approximately 5 psi lower ie...... if the starboard bank registers 105, the port bank would normally register 100.
Your quoted figures of 62-65 are way too low for a 1984 V6 engine.
