boxchevyman
- Mar 16, 2014
- 61
I have a 1960 Evinrude lark 2 40 hp
I took a video of what I?m experiencing which I think might help describe my problem better than anything I can write. The audio is not good but every time you see the engine shake it like cuts out and it not throttle up it will die.
Link to YouTube video: https://www.youtube.com/watch?v=e1alp7oTeOw&feature=youtu.be
Some background info:
? Coils are not original and they are not cracked, have a date of ?75? stamped on them, appear to be in good condition.
? Points look ok and they are set to .020.
? New plugs that are set to .030.
? New spark plug wires and boots.
? Carb was taken apart and sprayed out with carb cleaner, but did not install carb kit.
? Carb was bench set.
? The wiring is a mess but the two coil ground wires are isolated and are not grounding out.
So I don?t have a clue. Any help would be appreciated.
James
James
