Hey guys I am new to outboard motors and forums both. I recently bought a johnson 9.9 (10E76G). when I bought the the motor it would barely idle for longer than a few seconds which i attributed the the top coil having 2 large cracks in it , but both cylinders read 95 PSI on compressionn gage so i bought the motor anyways as it was very cheap. A couple weeks ago i replaced the cracked coil with a brand new one and switched out the champion plugs for NGK B7HS and the motor started up ran in the barrel great (from idle.to WOT). Since then the only work iv done on the motor was replacing the gear oil in the lower unit, but today when I put the motor on the barrel i could not get it to start for the life of me and the gas is brand new with outboard mixing oil at 50:1. I checked both plugs for spark again and all was good there can smell gas so fuel must be coming through the line. should my next step be to order a carb repair kit and attempt a repair? What could have changed so drastically in 3 weeks of sitting?
