Hi there, I had out my Boat today and was having some trouble with my overheat alarm horn I assume, When I tried to get up on plane alarm would sound in a solid tone until I dropped rpms, engine was pumping water fine and was not hot oil ball primed up.. the 3rd time I tried to get on plane alarm sounded and boat bogged down and shut off and now the motor will not even crank when I try to start, just simply 'Clicks' once when I turn the ignition. Is there something that may need reset and also can my alarm horn be bad or maybe I have a thermostat issue? any info on why my alarm is going off or how to get my boat to start again is greatly appreciated. Thank You. Jesse
