Hi,
I have a 99 johnson 35hp. (j35pl3eem) that i believe has the c.r.o. oiler system. The last trip out it melted the recirc lines and got the back of the coil pack hot enough to singe the edges. It would start after we let it cool but would shut down or die out when throttled up and not start until we cooled it down again (no spark).The water pump seemed to be doing ok as it was spraying water out the indicator nozzle.Im thinking it wasnt oiling due to it using a very small amount of oil compared to normal.I checked compression today to make sure i didnt completely fry it and had 119-120 on all 3 cylinders.My question is how hard is it to bypass this oiler system?Do i leave the recirc lines in place or plug them up ?also what about the level sensor in the tank?Ive been looking but not finding a complete procedure to get rid of this oiling system.I would greatly appreciate any help on this.
Thanks ,
Larry
Thanks ,
Larry
