motor starts easy and runs good. but has low power and wot rpm. compression is 35psi in both cylinders when spinning motor by hand. I even compression tested both cylinders while running on one and testing the other and still only got 60psi. removed bypass plate, pistons are clean and smooth, rings are not stuck. im stuck on why compression is so low. could the ring grooves be worn to allow blow by? any ideas appreciated.
