Re: 1985 150 GT Johnson... How to disable fast start?
Update:
I adjusted the cable running from the fast idle lever so that it barely moves the timer base when pushed all the way up.
Now, I adjusted the needle so that It points to TDC when cylinder #1 is all the way out. Had all plugs pulled, key in on position, timing light on #1 plug wire, and #1 plug firing against block, and the throttle wide open. Jumped the starter and it read about 14*, BUT it was 14* on the marks that are supposed to be #2 cylinder. WTF?
I dunno what I'm doing wrong?
