1972 18hp evinrude, Model# 18202R/ head bolt torque specs & sequence
whitejd12
I'm re-installing a new head assy and not sure what torque and sequence to tighten bolts. Also, is there a torque for the 3 thermostat bolts? Thanks a lot!!
boobie
Re: 1972 18hp evinrude, Model# 18202R/ head bolt torque specs & sequence
96-120 in. lbs. for the head. Start in the center and work your way out in a spiral pattern. 60-80 in. lbs. for the thermo bolts.
HighTrim
Like so.
whitejd12
My torque wrench reads foot pounds. How does that convert?
nwcove
divide inch lbs by 12
whitejd12
So 8-10 ft lbs, right?
HighTrim
yes
whitejd12
What about the torque on the spark plugs?
HighTrim
20 ft/lbs, never actually torqued a plug though. Snug em up, then about 1/4 turn more. Just by feel. Seen a few on here that stripped the threads using a torque wrench on them.
whitejd12
Haha. Yeah that's why I had to replace the head. Oops. Thanks for your help. Got it all back together.
boobie
1/4 turn is what I use also. An old aircraft mechanic told me that years ago.
