I have been fixing up my 56' evinrude fleetwin and it has been running better lately. The final problem that I have is tuning in the high speed control. When I go up to full speed, it does not go very fast at all, maybe 1/4 the speed it should be going. Then as I turn it in slowly waiting for it to respond, it never changes until it is in far enough that it dies. Then after running it for a bit, it will start going at the full speed it should. The high speed control still will not control it at all. If I turn the motor off, when I start it again it goes slowly again. The motor has good compression and I have done a carb rebuild, and added new spark plugs, points, and coils.
