Hi , having problems with my motor it dies on turns and cuts out .Took to repair shop they said motor junk , took compression test lower 2 cylds got 120 psi, upper got 40 psi ,can you rebild this cyl ,shop says you cant. prev. owner had carbs done before i got it. any info would help ,thanks
