coast2coastdesigns
- Oct 25, 2013
- 16
Recently purchased my first boat about 3-4 months ago. Pretty clean 95 Promaster with 200 OceanRunner. When talking to the owner originally he stated that there was a cold start issue that ended up being related to a primer issue. Not exactly sure what the part was called specifically, but it was replaced and the cold start issue was resolved. Since I have owned the boat there is still an issue with initial startup and idle. Engine hot or cold. Start engine, runs a couple seconds and dies. Will also die at a very low idle occasionally. After a couple tries it'll start and idle perfectly fine. After being started I can hear the idle come down slightly and know that it will not die on me. I've gone a full day on the lake without it acting up, but more often than not it will start and die on me about one or two times before it will start and run as designed. I did have an issue two weeks ago with a split fuel line between the carbs that ended dumping allot of fuel. I figured that initially there was a small leak in that line and it was loosing fuel pressure between spots while fishing, but even after I fixed the fuel line the condition was still present. Supposedly the engine was decarboned but I don't think anything was done to the carburetors and I don't think the plugs were changed either. Compression was also checked before purchase and all checked out. Seems like a fuel issue to me for sure, but I'm not exactly sure of the best way to go about the diagnosis procedure. Any help would be great. Thanks!
