1976 9.9 Johnson carb
Quackattacker
So I recently cleaned the carb and rebuilt it on my 1976 9.9 Johnson. I tool out the lean/rich screw and have no idea how to adjust it now. Do I turn it all the way in then adjust it from there? Help please
wrmdunker
Re: 1976 9.9 Johnson carb
You have the single SS carb. Start at 1.5 turns out and it should start up. Fine tune on the water at 1/8 turn and run a few seconds before moving again. If the needle is bent or worn you may want to replace.
I have the manual for the 1977 and it says start at 1.0 turn out.........
