cptnmorgan
- Sep 30, 2011
- 4
Hello,
I can't get my engine running. It ran for about a second then when I turned throttle it died and now it wont start again.
I have changed everything from oil and spark plugs. My problem may be in the throttle grip, as the shift, start, positions are worn out so I'm not sure where it should be for starting. can anyone tell me what the starting point and shift point is for my motor and how I can't visually tell? Can I notice the right spot from the timing plate?
