well started in on this 40 hp evinrude did a spark and compression test, compression was fine no spark. pulled the flywheel found both coils were cracked. I replaced both still no spark, so I replaced both condensers still no spark. replaced points and set them with timing pointer, got spark on cyl 1 no spark on cyl 2. took the coil on cyl 1 and swapped with cyl 2 spark on cyl 1 only swapped condensers and points with cyl 2 still spark on only cyl 1 which doing these test shows me that the coils, points and condensers are in working condition. removed the kill wire from points on cylinder 2 still spark on cylinder 1 only.made sure no oil had seeped through onto the plate and points clean as a whistle. The only thing I haven't done is replaced the plug wire and the timing plate, and turned motor over my solenoid after disconnecting key switch harness what else could there be? ???
