I started up the boat a couple days ago and, after it ran for approximately 5 minutes (Out of water but with hose/rabbit ears attached), a constant, screeching alarm began to sound from the throttle control area.
I recently had a new impeller put in, the gear oil changed and a carb rebuild performed. I thought that it may have something to do with the VRO or possibly the oil tank as I noticed that, prior to starting the engine, the bulb primer for the oil line was rock hard. Any ideas on what the alarm is telling me?
