77 johnson 35
- Apr 3, 2014
- 3
It has been setting 12 years , the carb is good i even tried a second carb, if i prime it( actually squirt fuel mixture into the throat of the carb) it will run till that gas is gone and die , fuel gets to the carb bowl and pasages are clean and clear
could it be a leaf valve?
Thanks in advance for any advice
