1989 Evinrude 110 VRO V4 linkage adjustment
aaron1956
Good Saturday morning everyone. I have been a member here for a while but haven't posted much. Can someone tell me what I need to do to get more throttle in REVERSE? The motor runs fine in forward but I can't get enough throttle to even back off the trailer. The rpm's barely increase above idle speed. (My tach doesn't work so not sure what rpm's are.)
My boat is a Procraft 1660V. I have a few more questions about this motor and boat but I will do a separate thread later.
Thanks.
boobie
Re: 1989 Evinrude 110 VRO V4 linkage adjustment
Do you have a binnacle mount control ??
boobie
Okay, where is the box mounted at ??. On a center console or the side of the boat.
aaron1956
It is mounted on the side of the boat. The gear shift and throttle on single lever. I can take some pics of motor linkage if that would be helpful.
boobie
Post some pics of the control.
