91Force
- Jun 12, 2013
- 15
hey all
So i got a new motor put on the boat and once i received it back from the service shop i had start problems from the get go. initally i would turn the key and nothing would happen no clicks just the electronic choke when the key was pushed in, i rang the shop back and asked why , he talk me through moving the controller so it engaged neutral , still no avail , after about 20 attempts it finally kicked and ran perfect over the xmas holidays.
Now 2-3 months later im slowly having problems with the same issue , so i swapped out the old neutral starter switch hoping that was the problem, still nothing , still wont start. So i checked the fuse running to the starter solenoid , seems fine so i tested the solenoid ( dont have tester ) but with a wire which i was told to try using the main battery terminal to the yellow wire terminal and it finally kicks over. i pulled all the wires off to the solenoid and cleaned them all but still no joy when turning the key , nothing its like the battery isnt connected. no clicks just the elect choke. not overly sure if the solenoid is stuffed but going to get a new 1 in the morning.
Is there anything i havent tried ?
almost at the end of my tether any input would be greatly appriciated.
