2004 johnson 115 saltwater series just took carbs off cause my motor wasn't idling and barely starting. at high rpms it's fine , but why would it run fine at high rpms if the float bowls are cracked all four are cracked and warped . One float was way higher then the others and I even found a silver fish in one carb. Any how replacing all this will hopefully help regain an idle any thoughts?
