All new ignition components and plug wires. Points new, clean and gap set properly. Armature plate grounded to block, as it should be. Top cylinder wire sparks intermittent. Bottom cylinder wire no spark. I have pulled flywheel 4-5x now to recheck everything and make sure points are spotless.
I decided to put wires on spark plugs and hold them against the block to see what happens. I have spark on both top and bottom this way.
There doesn't seem to be anything else I can do to address the spark to get it to jump 1/4". A friend suggested to gap my spark plugs at 0.025 instead of 0.030 and see if I can get it going that way.
Thoughts?
Thoughts?
