David/Maine
- Mar 31, 2014
- 2
Hello folks, brand new here. I have a 1989 johnson 60 hp vro. last year I had the oil portion of the pump disconnected. we used the boat multiple times over the summer with not one issue. at the end of the summer, the last time I used it, we boated for about 3 hours then anchored up to have lunch and let the dogs swim. When I tried to re start the engine, it would not run. I got it to sputter a couple of times but no go. I tried everything I could think of, I changed plugs. no avail. I had to get towed in. once back to the house, I hooked the ears up and wham, fired right up and purred like a kitten. I ran it for about 5 minutes it never skipped a beat. I disconnected the fuel line and let it run out. cover er up and have not started it since. I am getting ready to get the cover off of the boat and get it ready for spring fishing. does this issue sound like a fuel pump issue or something different? my other question is, if it is a pump issue, can I replace the vro pump with a straight fuel pump? Thank you very much for your time in reading this and for any advice you may have!
David
David
