I've got an '87 Johnson 70 that has been sitting for quite a while. The only way to keep it running is by choking it before it dies. So first thing I'm going to to is rebuild the carbs. I've got the carb kits and I'm ready to start but I have a few questions.
First at the top of the body running perpindicular to the body is an opening on both sides that has a screen placed on each end. I haven't seen any mention of servicing / replacing these two screens. What are these for? Air flow?
Second, on a rebuild like this, is it necessary to replace the core plugs? I haven't seen much mention of replacing these. the manual says don't do it unless you see them leaking? Not sure about that.
Third, apparently there are two different possible low speed types of jets and needles. One is the long needle and the other looks like a shorter screw. Are both of these types adjustable and if so what is the procedure?
Thanks for your help!
