Geauxfish11
- Aug 24, 2013
- 6
I have a 6hp Johnson 2 stroke that overheated. I was told by the repair shop that it would cost $1000 to replace pistons, gasket, and bore cylinders. Since that is more than the motor is worth I declined but I am going to try to fix it myself. My main concern is if I need to bore the cylinders and if I need to replace pistons. Compression in each is around 70 right now. I will attach pictures this afternoon of the pistons and cylinders so that y'all can hopefully tell me what I need to do.
