Re: 1990 140 hp Johnson fires up and dies.
Who knows? I don't know your engine storage procedure. Maybe gas left in the carbs thru the winter. Dunno.
But, If it fires, and then dies, it is a sure sign the idle circuits are clogged.
Try this as a test....rotate the red lever on the primer solenoid to the manual position. Start the engine, and before it dies, try to rotate the red lever back a little to find the sweet spot where just enough fuel leaks past the primer solenoid to keep it running. You follow?
You will be supplying fuel thru the primer solenoid system, bypassing the carb idle circuits. It will run like that, but it will be crappy. It will prove out whether the idle circuits are clogged.
Oh, by the way, when you are in the carbs, especially the throttle bodies, inspect those holes carefully. Verify that they are closed up. Find that defect. Don't just blast it with carb cleaner and not really find exactly what the problem was.
I had a 25 Merc in the shop last week. Single carb. It would start, run for about 20 seconds, slowly die away, and stall.
I pulled the carb, opened up the calibration pocket area on that carb (they all have something like that), and found two tiny holes, and sure enough one of them was plugged solid. Use the wire, carb cleaner, reassemble, start and run. Woo hoo...
Those holes are typically very very small, like about 5 thousands in diameter. They pass gasoline through to the venturi bore, right at the throttle butterfly. You can see them if you look very carefully, from inside the venturi, coming thru the wall.
