Hi guys,
I got a 1996 Evinrude 150 intruder, the last couple times out last fall if I were to let it idle for a minute than take off it would stall on me, have to restart it and than it will go,
I have a few things that I want to replace, fuel filter, hoses etc, I removed the fuel filter (above the vro pump) to replace it and it was full on straight oil, I also removed the main fuel line going to the motor and there was oil in there too, I removed the vro pump and everything inside looks good, even though it looks good inside can it still be needing replacement,
Thanks
Thanks
